Pure Motivation
To Motivate
Our Brothers and Sisters Only Groups have now been made private. If you wish to join you must click on the usergroup link and apply.
Top posters
zaharah (1191)
dangata (623)
sister harb (539)
nazleen (506)
Aisha (368)
EbonyRose (352)
Full of hopes (172)
Mila (144)
Tabu (108)
sadiq (97)
» Be On Your Guard...
Mon Jan 15, 2018 7:37 pm by Abu Zainab
» The Sadaqa (Charity) We Give Daily.
Tue Jan 09, 2018 1:05 pm by Abu Zainab
» Shortcuts To Paradise/Jannah.
Mon Jan 08, 2018 8:29 am by Abu Zainab
» Welcome to the Daily Grind where you can unwind
Mon Dec 25, 2017 12:00 pm by sister harb
» Consider Ayat 46 of Surat Kahfi.
Thu Aug 17, 2017 7:42 pm by Abu Zainab
» Tawheed In Summary.
Mon Jun 26, 2017 2:14 pm by Abu Zainab
» Inspiration For Excellent Action.
Mon Jun 26, 2017 1:52 pm by Abu Zainab
» Remembering Death.
Mon Oct 17, 2016 7:37 am by Abu Zainab
»  Just A Minute !!
Thu Oct 06, 2016 7:43 pm by Abu Zainab
» His Heart Never Sleeps.
Sun Sep 04, 2016 6:10 pm by Abu Zainab
» Of Scrupulousness and Little Laughter.
Fri Aug 26, 2016 6:55 pm by Abu Zainab
» Do You Know The Qur'an?
Fri Aug 12, 2016 6:10 pm by Abu Zainab
» Signs Of The Sweetness Of Imaan.
Fri Jul 01, 2016 6:03 pm by Abu Zainab
» Seeking The Beloved.
Fri Jul 01, 2016 5:48 pm by Abu Zainab
» Mind That Food and Drink.
Sun Jun 05, 2016 5:18 pm by Abu Zainab
» ALLAH: The Supreme Name.
Sun Jun 05, 2016 5:02 pm by Abu Zainab
» Tawbah is Obligatory.
Thu May 12, 2016 11:42 am by Abu Zainab
» Cookie Pizza
Fri Apr 29, 2016 10:07 am by sister harb
» Prophethood As A Circle.
Mon Mar 21, 2016 11:05 am by Abu Zainab
» Benefit of Turmeric
Tue Mar 08, 2016 7:22 pm by zaharah
» Banana milkshake
Tue Mar 08, 2016 7:15 pm by zaharah
» Never give up on your Deen
Tue Mar 08, 2016 7:02 pm by Admin
» So Comforting!!
Wed Mar 02, 2016 5:10 pm by Abu Zainab
» Absolute Existence Of Allah and Our Non-Existence.
Wed Mar 02, 2016 6:41 am by Abu Zainab
» Consider These Ahadith..
Wed Mar 02, 2016 6:21 am by Abu Zainab
»  Shaykh Abu Hamid al-Ghazali's Counsel.
Wed Dec 23, 2015 6:18 am by Abu Zainab
» The Sunnah In Crying.
Sat Dec 12, 2015 1:01 pm by Abu Zainab
»  And Muhammad is His Messenger.
Sun Nov 08, 2015 1:49 pm by Abu Zainab
» Guest Book/الترحيب بالضيوف
Tue Oct 13, 2015 6:34 pm by sister harb
» Afghan Sweets
Tue Oct 13, 2015 5:22 pm by sister harb
You are not connected. Please login or register
Pure Motivation » Member Showcase » Recipes 5 star cooking/ وصفات لأطباق شهية » Dolma/Stuffed Grape Leaves with Olive Oil
View previous topic View next topic Go down  Message [Page 1 of 1]
1 Dolma/Stuffed Grape Leaves with Olive Oil on Thu Jun 09, 2011 1:59 pm
sister harb
All-Star Member
All-Star Member
Known as dolma or sarma in Turkey.
For the Stuffing:
2 cups rice
½ white or yellow onion (chopped)
½ cup pine nuts
1/3 cup chopped fresh mint (or 2 tbsp dried mint)
1/3 cup chopped fresh flat leave parsley (or 2 tbsp dried parsley)
1 tsp paprika
1 tsp ground black pepper
1 tsp cumin
1/3 cup olive oil
2 lemons
For Rolling & Cooking:
1 jar grape leaves or as much as it takes to finish the stuffing above
½ lemon
2 sprigs fresh mint
2 garlic cloves (sliced)
2 tbsp olive oil
Water (as much as it takes to fill ¾ of the pot)
Preparation:
Mix all the stuffing ingredients together. The stuffing should look like this:
If you are using a pickled grape leaves, remove from the jar and run under cold water and squeeze to let all the water out.
Take one grape leaf and place on a cutting board or well cleaned counter. If your cutting board is white, it will turn to a greenish/brownish color from this because of all the juices as you can see in the pictures Sad Make sure to place your leaf the smooth side down, facing the board. When you roll it, the smooth side of the leaf will be on the outer side.
Remove the stem. Place some stuffing on the leaf.
Start rolling the grape leaf by first making one fold forward and then folding both sides in.
Keep rolling forward until the leaf is completely rolled.
Place neatly in a pot. The first round of placing the sarmas in the pot looks like this:
When the pot is full, the sarmas should look like this:
Once all the grape leaves are rolled, place the fresh mint leaves on top along with sliced garlic. Pour ½ lemon juice on top and drizzle the olive oil. Add water enough to cover ¾ of the pot.
Place small plates on the sarmas to put weight on them so they do not open during the cooking process. Cover and cook on medium heat until water boils. Reduce the heat once the water boils and start cooking on low for 45 minutes. Make sure the water does not dry out before cooking. I always take one sarma and taste it before I decide if the rice inside has cooked or not. Enjoy warm or cold.
Note: You may also use the stuffing (with meat) used in the Karısık Dolma recipe. You may also use the vegetarian stuffing for making dolmas with eggplants, zucchinis or bell peppers.
2 Re: Dolma/Stuffed Grape Leaves with Olive Oil on Thu Jun 09, 2011 2:28 pm
Mila
Senior Member
Senior Member
oh thnks for this recipe i had this at resturant and wondered how they made them
I need help in finding a recipe..i dont know what its called
but its squash that has had its insides taken out and stuffed with rice and meat
do u know of this?
Conversation should be pleasant without scurrility, witty without affectation, free without indecency, learned without conceitedness, novel without falsehood.
William Shakespeare
3 Re: Dolma/Stuffed Grape Leaves with Olive Oil on Thu Jun 09, 2011 2:38 pm
sister harb
All-Star Member
All-Star Member
I have made sometimes filled squash too.
Here you can find something (by Turkish style):
Stuffed Vegetables
http://mediterraneanturkishfoodpassion.blogspot.com/2008/04/kark-dolma-mixed-dolmas.html
4 Re: Dolma/Stuffed Grape Leaves with Olive Oil on Thu Jun 09, 2011 5:46 pm
Mila
Senior Member
Senior Member
Jazakallah Khair that is exactly what i needed
William Shakespeare
5 Re: Dolma/Stuffed Grape Leaves with Olive Oil on Sun Jun 12, 2011 10:55 pm
Aisha
Senior Member
Senior Member
Thanks sister for this, I want to make them for Ramadan this year, InSha Allah
View previous topic View next topic Back to top  Message [Page 1 of 1]
